menace387
Jun 28, 2021Aspirant
Question on Ethernet port aggregation- CM1150V Voice Modem and R60009P Router
I would like to know if i would benefit from ethernet Port aggregation. I have one ethernet line coming out of my modem into my router. I have 1 gb interenet coming into the modem. Does the modem s...
- Jun 28, 2021
Does your wifi host router support LAG on it's WAN side?
Jun 28, 2021Guru - Experienced User
menace387
FURRYe38 wrote:Does your wifi host router support LAG on it's WAN side?
https://en.wikipedia.org/wiki/Link_aggregation
Not sure. I will have to check the manual. The router is a Net gear Nighthawk R6900P.
I will also check out the link on for link aggregation.
