Ed_R
Apr 28, 2022Follower
Question on USB port on C6300 hub?
Can I plug a usb hub into my C6300 and then plug two 5 tb externals into the hub nad be bale to access them both using Windows? I don't think my Sony X700 bluray player will be able to see this either.
Potentially yes?
Reason I say potentially is I've seen people able to do it and then others where it caused issues.
And I've even seen it where 1 drive caused issues.
I use an 8TB USB Seagate Backup Plus Hub drive with two USB ports on the front. Windows happily shows devices plugged into these drives.
