m_brando
May 13, 2021Star
Question on which WiFi 6 Cable Modem Router plus Satellite/Extender to use Orbi AX4200 or AX6000
Hello Netgear community, I am not completely networking savy but I do ok setting up my home office. I am moving to a new home, 4BR about 2700 sqft. I run my business out of my home. I currently h...
- May 13, 2021
The CBK750 doesn't have a 2.5Gb LAN port and it's LAN ports are only rated at 1000Mpbs. The CAX80 has one 2.5Gb LAN port that can be used in either router mode or modem only mode. So you could connect your 2.5Gb supporting PC to the CAX80 at 2.5Gb speeds. a EAX80 would match up to the CAX80 to extend it's wifi signal.
