jintogens
Jun 25, 2022Follower
Question regarding Netgear Nighthawk Modem/Router combo with Spectrum service
Hello all! First post and I'm quite perplexed about a situation that has happened to me. I recently bought a house and had to frantically set up internet so that I might still be able to work fro...
Jun 25, 2022Guru - Experienced User
both michaelkenward and microchip8 are right. Netgear doesn't update the firmware. Its pushed when spectrum provisions your modem.
But you said you already bought a router? What router did you buy? Not sure when spectrum plans on it but currently, they aren't charging to rent modems. So you could go modem---->router and might have a better setup (as the C6300 is getting a bit older and isn't docsis 3.1)
michaelkenward
I thought of throwing that idea into the mix.
It is the preferred (by people who like to control their networks) option. It lets you buy a router with far more features and options than the combo options. And you can change either bit of the chain depending on your Internet technology.
Switch from cable to full optical, for example, and you can keep the router and connect to the Optical Network Terminator (ONT). Unlike DSL combos, cable modem/routers don't seem to have a "router only" option.
