MiloZoe
Jan 28, 2021Tutor
Quickie Questions on Modem/Router Behavior
Nighthawk X4 AC 3200 C7500 Modem/Router In operation approximately 1 year and have 24 connected devices Question One Periodically to no particular time frame, the unit drops all the connecti...
- Jan 31, 2021
You have errors in your line according to the logs and connections page. try checking for kinks, damage, old/loose/cheap/bad connections.
If you have any splitters, amplifiers, attenuators in the coax line, remove them and just direct connect the modem to where the coax enters the home. try that first.
MiloZoe
Jan 29, 2021Tutor
Please see the attached screenshots, taken today. I have to admit that I know nothing about interpreting this data. Also I thought of doing a modem/router factory default reset, however since the power cycling worked, I thought that a full reset would be extreme.
Thanks
Jan 29, 2021Guru - Experienced User
Photos have to be approved by a moderator and it can take a while. You can attach them individually by clicking on the "choose file" option when posting. those we can download/see right away
