MiloZoe
Jan 28, 2021Tutor
Quickie Questions on Modem/Router Behavior
Nighthawk X4 AC 3200 C7500 Modem/Router In operation approximately 1 year and have 24 connected devices Question One Periodically to no particular time frame, the unit drops all the connecti...
- Jan 31, 2021
You have errors in your line according to the logs and connections page. try checking for kinks, damage, old/loose/cheap/bad connections.
If you have any splitters, amplifiers, attenuators in the coax line, remove them and just direct connect the modem to where the coax enters the home. try that first.
MiloZoe
Jan 30, 2021Tutor
Jan 31, 2021Guru - Experienced User
