sulo366
May 06, 2020Aspirant
R6100 AC1200 Dual Band Router and CM400 Modem
Good Afternoon Everybody, I have a R6100 AC1200 Dual Band Router, and a CM400 Cable Modem. May I learn the highest Download/Upload Speed I can get with R6100 AC1200 Dual Band Router? also may I...
May 06, 2020Guru - Experienced User
The modem can handle up to 343 Mbps. The router should be capable as well.
- sulo366May 06, 2020Aspirant
Thank you for your reply FURRYe38 , but on the Amazon page of Netgear CM400 and also couple other websites, (link below), it says it only provides speed up to 100mbps. That's why I am confused.
https://www.amazon.com/NETGEAR-WIRELESS-Spectrum-Cablevision-CM400-1AZNAS/dp/B0111MRLES
- FURRYe38May 07, 2020Guru - Experienced User
Lets review the official spec sheet from NG:
http://www.downloads.netgear.com/files/GDC/datasheet/en/CM400.pdf
