Jaughn_Dough
Jul 06, 2019Aspirant
R6200v2 Unable to open ports
I recently moved into a new apartment and have been trying to set up my a port on my network to run a server, but it is not opening. I have already allowed the port through my firewall and even t...
- Jul 06, 2019
> Could you explain how I find the address? [...]
Which "the address"? Every network interface has one (and your
router has two, which you seem to have found).> My Internet IP address is being obtained dynamically from the ISP and
> my Internet Port IP address is 192.168.1.64. The Router Information IP
> address is 10.0.0.1.And there it is. "192.168.1.64" is a private address, assigned to
your NAT router by some other NAT router, hence "double NAT". Any
effective port forwarding would need to be done on the other router
(which, presumably, but not certainly) has a public address on its far
side.The R6200v2 would normally use "192.168.1.*" on its LAN side, but it
detected that subnet on its WAN/Internet side, and thus switched to
using its alternate LAN subnet, "10.0.0.*" to avoid the conflict.> Not sure if any of that is helpful or not.
It's everything which is needed to reveal that you're approximately
doomed.The only solutions I know are: 1) to ask your ISP for a real public
address (which I'd guess might not be possible with the current
apartment service scheme), or 2) to use a tunneling service like the one
mentioned in another recent thread (near the end):
Jaughn_Dough
I receive my connection from AT&T's fibre service. They partner with the complex I am in, but are considered seperate, both in costs and service provided.
Could you explain how I find the address? The WAN setup has the default DMZ Server box checked which is the same as my IP as my local PC. My Internet IP address is being obtained dynamically from the ISP and my Internet Port IP address is 192.168.1.64. The Router Information IP address is 10.0.0.1.
The address from my PC is 10.0.0.2.
antinode
Jul 06, 2019Guru
side.
doomed.
