Retired_Member
May 31, 2019R6260 ROUTER WON'T SHOW WIRED COMPUTER
I just purchased a Netgear R6260 Router, with FIRMWARE version V1.1.0.52_1.0.1. I installed this at work to replace and overheating ASUS router. Everything works great except the router under attached devices will not show our old 1980's unix based DISC server. We have a few computers connected, a camera system, and phone system and everyone of them shows up under connected devices. The server is the only piece of equipment that will not show up. If I plug in the old Asus router the DISC server pops right up under connected devices. For some reason this router will not show it. On all of our older routers we manually assigned the DISC server an ip address under the router settings so it would always stay the same when the dhcp lease time expired. I don't know how to do this if I can't see it under the router attached devices. This server is wired into the router. I have tried multiple ports on the router and in the 16 port switch and it still will not show up. I know the cable works correctly because everything functions properly when the old router is plugged back in. I am not an IT guy so please be kind. I am just another employee trying to keep things going to help out. Any help would be greatly appreciated.
1 Reply
> [...] our old 1980's unix based DISC server [...]
Not a very detailed decription of anything. Is there a console
terminal on this mystery machine where you can log into it without its
being on the LAN? If you can talk to the thing, then output from
commands like "uname -a" and "ifconfig -a" would be interesting.> [...] If I plug in the old Asus router the DISC server pops right up
> under connected devices. [...]And when it does, what do you see? Copy+paste is your friend. Do
these two routers use the same LAN IP subnet ("192.168.0.*", or
whatever) for their IP addresses?> [...] On all of our older routers we manually assigned the DISC server
> I can't see it under the router attached devices. [...]
I know almost exactly nothing about your mystery machine, but...I would not expect a seriously old UNIX(-like) system to use DHCP to
get its IP parameters. I'd expect it to be configured with static IP
parameters (independent of the router and its reserved dynamic
addresses). In such a case, that system might not try to communicate
with the router -- certainly not for DHCP -- so the router might not
notice it. (And if it's configured for a different IP subnet, then it
would be pretty thoroughly unable to communicate with the router.)> [...] I have tried multiple ports on the router and in the 16 port
> switch and it still will not show up. [...]If it doesn't work somewhere, then it shouldn't work anywhere.
> [...] I know the cable works correctly because everything functions
> properly when the old router is plugged back in. [...]
A better clue would be a positive indication on a port-status LED
indicator on the router (or network switch) where the cable is
connected. Even better if there's a similar indicator on the computer
itself, but a very old system might not have one. But I'd bet more on a
bad (inappropriate) configuration than on bad hardware.
