Ramjet44
Mar 30, 2020Aspirant
R6350 router won't connect to Xfinity/Comcast Modem
I bought an AC1750 Smart WiFi Router, Model R6350. I have tried to use the Nighthawk app to install it. The app give me an "wire not connected" error or something like that. I can see the Netgear rou...
Mar 31, 2020Guru - Experienced User
Factory reset the modem by pressing the back reset button for 15 seconds then release. Wire connect your PC to the back of the modem. Use a web browser, IE11 or Firefox and walk thru the setup wizard at 192.168.0.1. This should help you get the modem setup. Let us know how it goes.
Ramjet44 wrote:I bought an AC1750 Smart WiFi Router, Model R6350. I have tried to use the Nighthawk app to install it. The app give me an "wire not connected" error or something like that. I can see the Netgear router in my Wireless Network Connections but when I login with the network key it won't connect.
I saw on the community board where someone accessed the router interface and ran a "test" which fixed their issue. I can't get the interface to come up on my laptop with an ethernet connection.
I also ran a diagnostic test on the Xfinity modem and it tested fine. Any advice? Thanks
- Ramjet44Mar 31, 2020Aspirant
Thanks Furry. I couldn't get my laptop to recognize the etheret connection from the modem. My modem is a Cisco DPC3939 and is fairly old. I think I'm going to take the router back and exchange it for a modem/router combo unit. Then I would have to worry about this anymore. I appreciate the response. Thanks.
