Victisha81
Apr 23, 2019Aspirant
R6700v3 Guest Wifi Configuration
Nighthawk AC1750 Smart WiFi Router Model R6700v3 - Not so SMART... Can't disable guest wifi after enableing it for our guests....
I turned my guest wifi on for our guests on Easter, I can n...
Apr 23, 2019Guru - Experienced User
Please post about this in this forum for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Be sure the routers Firmware is up to date.
Good Luck.
Victisha81
Firmware is up to date. From the looks of it I’m not the only one with this issue. Thanks for the idea tho. And I reposted on the section you referred me too.
- FURRYe38Apr 23, 2019Guru - Experienced User
:smileywink:
