Victisha81
Apr 23, 2019Aspirant
R6700v3 Guest Wifi Configuration
Nighthawk AC1750 Smart WiFi Router Model R6700v3 - Not so SMART... Can't disable guest wifi after enableing it for our guests....
I turned my guest wifi on for our guests on Easter, I can n...
Victisha81
Firmware is up to date. From the looks of it I’m not the only one with this issue. Thanks for the idea tho. And I reposted on the section you referred me too.
Apr 23, 2019Guru - Experienced User
:smileywink:
