TwinG's avatar
TwinG
R6900/AC1900 router compatible with the CM1150V modem ?
I have the R6900/AC1900 router and looking to replace my Comcast Xfinity modem (cable, internet and voice) with the CM1150V. Seeing if there have been an compatibility issues joining the R6900.. and the CM1150V.    Thanks.
  • Yes.
    The CM series modem is only and modem with voice support. It does not have a built in router.
  • FURRYe38's avatar
    Yes.
