shaulch
Jul 10, 2019Tutor
R7000 Tx rate is alway 54Mbps
Hi,
Till now, i didn't have any issue but now every device (Macbook , Ipad, Iphone, PC) is connected on 5Ghz but TX is 54Mbps.
RSSI : -37dbm
Noise : -95dbm
Phy mode: 802.11ac
Firmware: V1.0.9.88_10.2.88
Encryption - AES
Reboot , firmware upgrade , change channels - nothing . I alway receive 54Mbps (so in speedtest i get 30Mbps on 1GB Internet connection)
`Any idea ? is it HW issue ? SW issue ?
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Good Luck. - shaulchTutor
Answer myself,
Looks like some firmware upgrade remove the check from WMM checkbox .
I enabled WMM (Wifi Mulitimedia) in Qos menu and boom , the link TX speed increased.
Enjoy. :smileywink:
