Mrrgbg
Nov 26, 2017Aspirant
R7800 - Nighthawk X4S AC2600 Smart WiFi Router
I recently hooked up my R7800 wifi router to my modem using the ethernet cable, and I show on my computer settings and other devices, that I am on the netgear wifi. However, when I go the the router...
TheEther
Nov 26, 2017Guru
If you are sure that you are connected to the Netgear, then routerlogin.net should work. If it's not working, then you can always connect to its IP address. The default IP address is 192.168.1.1.
Mrrgbg
Maybe the 5th time was the charm...
I unplugged everything (again) but this time I pressed the factory reset button, the hooked everything up again. I also made sure any vpn was disconnected ... finally this time when I went to the login website, it worked.
Hopefully it will keep working. I do appreciate your assistance.
-Richard
