thedza49
Dec 20, 2020Aspirant
R7800 not recognizing external hard drive plugged in via USB
Hey Everyone, Title pretty much says it all. I have a 3.5 Western Digitial Red NAS drive that is 4TB plugged into an amazon external hard drive enclosure trying to get my router to recognize it....
Dec 20, 2020Guru - Experienced User
What format did you use on the drive? I think NTFS and FAT32 or EXT are ones that are supported by NG. Check the manual.
Does the external drive enclosure have it's own power supply?
- thedza49Dec 21, 2020Aspirant
I think I selected the first option on Disk Utility on my Mac which was the APFS.
The enclosure has it's own power source.
- FURRYe38Dec 21, 2020Guru - Experienced User
Ya, thats not supported on NG I believe. Try NTFS or EXT
- thedza49Dec 26, 2020Aspirant
THanks I realized that the drive has been formatted on my mac with a format that doesn't work with the router. I've tried to format the drive to a EXT4 format which should work. Wish me luck!
