SgtHartman's avatar
SgtHartman
Random disconnects: C7000v2 (Nighthawk AC1900)
Throughout the day, I experience random disconnects from the internet for roughly 30 seconds to 1 minute at a time. This will happen seemingly randomly, whether my computer is using the connection through ethernet, or my girlfriend is up late watching TikTok. I have contacted my ISP and gone through all of the regular troubleshooting, and I was hoping that someone could point me in the right direction!
My ISP is Breezeline, and I have contacted them repeatedly about this issue, since it has been ongoing since I got their service and the Netgear modem in April. They have issued signal resets, gone through the process of unplugging and reconnection my modem, and even sent out a tech a little over a week ago. The tech said that nothing was wrong on Breezeline's end, and the only thing he did was replace a corroded connection on the outside of the buildings. I attempted to show him the error logs, and he said that he didn't understand what the logs were saying. Either way, a tech came out and could not fix the issue.
I'm not sure if this is an ISP issue or a modem issue, but I'm hoping that someone here can help me narrow down the root cause and solution. Below, I have attached my down/upstream channels and the event logs from the most recent times it occurred (twice in the last hour). Please let me know if you need any other information, and thank you in advance for your help!
TimePriorityDescription
2025-6-9, 20:22:52Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=54:07:7d:06:43:c8;CMTS-MAC=70:1f:53:99:e2:40;CM-QOS=1.1;CM-VER=3.0;
2025-6-9, 20:22:03Warning (5)DHCP WARNING - Non-critical field invalid in response ;CM-MAC=54:07:7d:06:43:c8;CMTS-MAC=70:1f:53:99:e2:40;CM-QOS=1.1;CM-VER=3.0;
2025-6-9, 20:22:00Notice (6)Honoring MDD; IP provisioning mode = IPv4
2025-6-9, 20:21:47Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=54:07:7d:06:43:c8;CMTS-MAC=70:1f:53:99:e2:40;CM-QOS=1.1;CM-VER=3.0;
2025-6-9, 20:21:14Critical (3)Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=54:07:7d:06:43:c8;CMTS-MAC=70:1f:53:99:e2:40;CM-QOS=1.1;CM-VER=3.0;
2025-6-9, 19:54:47Notice (6)WiFi Interface [wl0] set to Channel 11 (Side-Band Channel:N/A) - Reason:INTERFERENCE
2025-6-9, 19:48:54Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=54:07:7d:06:43:c8;CMTS-MAC=70:1f:53:99:e2:40;CM-QOS=1.1;CM-VER=3.0;
2025-6-9, 19:48:05Warning (5)DHCP WARNING - Non-critical field invalid in response ;CM-MAC=54:07:7d:06:43:c8;CMTS-MAC=70:1f:53:99:e2:40;CM-QOS=1.1;CM-VER=3.0;
2025-6-9, 19:48:01Notice (6)Honoring MDD; IP provisioning mode = IPv4
2025-6-9, 19:47:28Critical (3)Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=54:07:7d:06:43:c8;CMTS-MAC=70:1f:53:99:e2:40;CM-QOS=1.1;CM-VER=3.0;
2025-6-9, 19:47:25Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=54:07:7d:06:43:c8;CMTS-MAC=70:1f:53:99:e2:40;CM-QOS=1.1;CM-VER=3.0;
2025-6-9, 19:46:35Warning (5)DHCP WARNING - Non-critical field invalid in response ;CM-MAC=54:07:7d:06:43:c8;CMTS-MAC=70:1f:53:99:e2:40;CM-QOS=1.1;CM-VER=3.0;
2025-6-9, 19:46:31Notice (6)Honoring MDD; IP provisioning mode = IPv4
2025-6-9, 19:46:17Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=54:07:7d:06:43:c8;CMTS-MAC=70:1f:53:99:e2:40;CM-QOS=1.1;CM-VER=3.0;
2025-6-9, 19:45:44Critical (3)Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=54:07:7d:06:43:c8;CMTS-MAC=70:1f:53:99:e2:40;CM-QOS=1.1;CM-VER=3.0;
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel333000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityDisabledDisabled
IP Provisioning ModeHonor MDDhonorMdd(4)
Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
1LockedQAM2566333000000 Hz3.9 dBmV42.7 dB2982
2LockedQAM2561303000000 Hz4.1 dBmV42.9 dB1654
3LockedQAM2562309000000 Hz4.1 dBmV42.9 dB2744
4LockedQAM2563315000000 Hz4.1 dBmV42.7 dB29121
5LockedQAM2564321000000 Hz4 dBmV42.6 dB2451
6LockedQAM2565327000000 Hz4 dBmV42.6 dB2050
7LockedQAM2567339000000 Hz3.8 dBmV42.2 dB1751
8LockedQAM2568345000000 Hz3.7 dBmV42.5 dB1454
9LockedQAM2569351000000 Hz3.8 dBmV42.7 dB1756
10LockedQAM25610357000000 Hz3.6 dBmV42.5 dB1359
11LockedQAM25611363000000 Hz3.6 dBmV42.6 dB1658
12LockedQAM25612369000000 Hz3.7 dBmV42.7 dB1751
13LockedQAM25613375000000 Hz3.7 dBmV42.7 dB2991
14LockedQAM25614381000000 Hz3.8 dBmV42.9 dB1156
15Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
16Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
17Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
18Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
19Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
20Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
21Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
22Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
23Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
24Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
Upstream Bonded Channels
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA15120 Ksym/sec36800000 Hz47.5 dBmV
2LockedATDMA25120 Ksym/sec30400000 Hz48 dBmV
3LockedATDMA35120 Ksym/sec24000000 Hz47 dBmV
4Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
5Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
6Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
7Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
8Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
  • FURRYe38's avatar
    Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
    Correctables and un-correctables that should be mostly zeros.
    Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
    Be sure there are no coax cable line splitters in the between the modem and ISP service box.
    Be sure your using good quality RG6 coax cable up to the modem.
    Start with removing any amplifiers, signal attenuators, or splitters from the coax.
    From there check the line for kinks, damage, moisture in the line.
    Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
    Be sure to power OFF the modem for 1 minute then back ON.
    https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
    https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
    https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
    https://highspeed.tips/docsis-events/
    SgtHartman​
    • SgtHartman's avatar
      SgtHartman
      Thank you for all of the helpful information! I actually contacted my ISP again, and they're sending a technician today (surprisingly). I'm going to relay all of the information that you and Kitsap gave me to them, so thanks!
