SysopChris3
Sep 01, 2019Aspirant
Random disconnects of internet - AC1900 C7000v2 1.02.14
Model C7000v2, Firmware 1.02.14 I have tried several of the solutions found here without making any difference. When I loose internet I remain connected the same SSID. I notice this has happened whe...
Sep 01, 2019Guru - Experienced User
Does this happen with wired and wireless devices?
Try you PC with a wired connection.
Be sure there are not coax cable line splitters between the modem and ISP service box.
Contact the ISP and have them check the signal and line quality up the modem?
SysopChris3
Thanks for the reply!
Problem is wireless only.
Direct line. Also, this replaced a previous model/router on the same line without ever having this problem that was noticeable.
Do you know if there is there any type of logging I turn on that might capture some useful info. about when this happens?
ISP is Comcast. I haven't contacted them because there were no problems until I got the modem/router. My speedtest is still where it should be and the router says the connection is good.
- FURRYe38Sep 01, 2019Guru - Experienced User
Any Wifi Neighbors near by? If so, how many?Might check under Advanced/Administration to see if logging is available here.
- SysopChris3Sep 01, 2019Aspirant
Attached are my wireless settings.
2.4 was Auto, changed to 6
5 was 153, changed 60
It may take awhile to get results.
Thanks.
I would use channels 36 thru 48 on 5Ghz...Some devices may not be able to use channel 60 as this is a DFS channel.
Any other wifi neighbors near by?
