KiwiBoxer's avatar
Jun 19, 2020
Random Internet Disconnection on Both Wi-fi and Wired (CM1200 Modem)
I purchased the CM1200 modem back in March of this year and haven't had an issue with until the past month and a half. I'm having an issue where my internet will randomly disconnect on both Wired and Wireless at the same time. These disconnects can range from a couple seconds to a couple minutes. I called our ISP (Comcast) asking if they could find anything wrong and they told me that they were having no issues. I replaced our router, thinking that was the issue at first since the internet symbol on the modem stays on even during these moments of disconnect but the routers didn't. But the new router (TP-Link Archer C5400X) hasn't fixed it.
The modem is on the latest firmware version (V1.02.02). I've tried different ethernet cables on both the router and modem. On my router, I've tried changing channels, cloning my computers MAC address, setting up some IP configuration. On the modem, I enabled ethernet port aggregation. Nothing has worked so far. I'm thinking it's either a coaxial cable issue (but wouldn't my ISP see that?), or simply the modem itself.
Thanks for any help you can provide!
  • plemans's avatar
    log into the modem and get a screen snip of the cable connection page and the logs and post them back here.
    Also, if you have any splitters, attenuators, or amplifiers in line, remove them and direct connect the modem.
    • KiwiBoxer's avatar
      KiwiBoxer
      Guide
      I'm not sure how to attach multiple things so I hope an Imgur link of the screenshots is ok: CM1200 Screenshots
      Here is at least the event log if you're not ok with that.
      Thanks!
      Time Priority Description
      Fri Jun 19 10:00:22 2020 Warning (5) Dynamic Range Window violation
      Fri Jun 19 10:00:22 2020 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=28:80:88:b3:1f:d0;CMTS-MAC=00:01:5c:79:10:69;CM-QOS=1.1;CM-VER=3.1;
      Fri Jun 19 09:54:56 2020 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=28:80:88:b3:1f:d0;CMTS-MAC=00:01:5c:79:10:69;CM-QOS=1.1;CM-VER=3.1;
      Fri Jun 19 09:54:30 2020 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=28:80:88:b3:1f:d0;CMTS-MAC=00:01:5c:79:10:69;CM-QOS=1.1;CM-VER=3.1;
      Fri Jun 19 09:36:52 2020 Notice (6) CM-STATUS message sent. Event Type Code: 8; Chan ID: 79 80; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:b3:1f:d0;CMTS-MAC=00:01:5c:79:10:69;CM-QOS=1.1;CM-VER=3.1;
      Fri Jun 19 09:36:26 2020 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=28:80:88:b3:1f:d0;CMTS-MAC=00:01:5c:79:10:69;CM-QOS=1.1;CM-VER=3.1;
      Fri Jun 19 09:36:26 2020 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=28:80:88:b3:1f:d0;CMTS-MAC=00:01:5c:79:10:69;CM-QOS=1.1;CM-VER=3.1;
      Fri Jun 19 09:36:26 2020 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=28:80:88:b3:1f:d0;CMTS-MAC=00:01:5c:79:10:69;CM-QOS=1.1;CM-VER=3.1;
      Fri Jun 19 09:35:39 2020 Warning (5) Dynamic Range Window violation
      Fri Jun 19 09:35:39 2020 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=28:80:88:b3:1f:d0;CMTS-MAC=00:01:5c:79:10:69;CM-QOS=1.1;CM-VER=3.1;
      Fri Jun 19 09:35:38 2020 Warning (5) Dynamic Range Window violation
      Fri Jun 19 09:35:38 2020 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=28:80:88:b3:1f:d0;CMTS-MAC=00:01:5c:79:10:69;CM-QOS=1.1;CM-VER=3.1;
      Fri Jun 19 09:35:37 2020 Warning (5) Dynamic Range Window violation
      Fri Jun 19 09:35:37 2020 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=28:80:88:b3:1f:d0;CMTS-MAC=00:01:5c:79:10:69;CM-QOS=1.1;CM-VER=3.1;
      Fri Jun 19 09:35:37 2020 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=28:80:88:b3:1f:d0;CMTS-MAC=00:01:5c:79:10:69;CM-QOS=1.1;CM-VER=3.1;
      Fri Jun 19 09:34:54 2020 Warning (5) Dynamic Range Window violation
      Fri Jun 19 09:34:54 2020 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=28:80:88:b3:1f:d0;CMTS-MAC=00:01:5c:79:10:69;CM-QOS=1.1;CM-VER=3.1;
      Fri Jun 19 09:34:36 2020 Warning (5) Dynamic Range Window violation
      Fri Jun 19 09:34:36 2020 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=28:80:88:b3:1f:d0;CMTS-MAC=00:01:5c:79:10:69;CM-QOS=1.1;CM-VER=3.1;
      Fri Jun 19 09:34:35 2020 Warning (5) Dynamic Range Window violation
      • plemans's avatar
        You have t3 errors and power fluctuation errors. The snip just shows in the time the page was loaded but from looking at your log, the power must be spiking/dropping.
        If you didn't check your line and remove amplifiers, splitters, attenuators, do it now. If you already have, then I'd have your isp check your line.
