EnwErica's avatar
EnwErica
Initiate
May 14, 2022
Rax48 configurations with other equipment for best results
I have a nighthawk c7000v2 router/modem combo, an Arris SBG8300 router/modem combo and a nighthawk rax48 router. On one end of my house I have outdoor cameras and the other end my son has his “pro” ga...
  • plemans's avatar
    May 14, 2022
    Your a little stuck. here's why.
    The C7000 and the SBG8300 are both modem/router combo devices. And both have a modem only mode but not a router only mode.
    There is a way of getting a c7000 to act as a type of access point.
    If you want to try, here's the guide:
    Can I use a C6300 cable modem without cable intern... - NETGEAR Communities
    so if you can get that working, I'd go SBG8300----->C7000 (access point mode)------>RAX in access point mode.
    You'd need to hardwire in the C7000 and the RAX.
    If you can't get the C7000 to work as a type of access point then go:
    SBG8300------>RAX
    Reason why is the SBG has the better modem of the bunch. The RAX has the best routing capability.
