A2cents
Dec 17, 2020Aspirant
RAX80 - CM1150v port aggregation cancels wired iMac ethernet (OK if single cable router-modem link)
RAX80 & CM1150v with aggregated link & gigabit Xfinity giving me consistent gig+ speeds using Xfinity app. Imac wired to RAX80 cannot complete a speedtest due to ethernet disconnecting ("fix": ...
Dec 17, 2020Guru - Experienced User
I wouldn't use wan port aggregation. I had issues with it and while its nice for that extra uptick in speed, it wasn't worth it for me on consumer devices.
And it wasn't just netgear that had issues. I had a arris SB8200 that was consistently having issues with wan aggregation.
i stopped attempting it and switched to a cax80 or a cm2000 depending on what i have setup for speeds >1gig.
- A2centsDec 17, 2020Aspirant
I agree on SB8200 comment. I suffered speed declines after 1-2 weeks, then later after 1-2 days. Resetting either end of the aggregated link would address that issue but just not a reliable setup.
Hence the CM1150v modem as I switched off my landline and ported its #, on the off chance that aggregation might work. ...And it does work (up to 15 days up before provisioning for phone at 1.1-1.2 Gb/sec), except for my new calamity. My CalDigit dock is happy as a clam, just not the iMac itself.
A2cents
- plemansDec 17, 2020Guru - Experienced User
Port aggregation has been hit or miss since it came out.
See the move from netgear to devices like the cm2000 or CAX80. the 2.5g port is much more reliable than fighting with port aggregation.
You don't see quite the same issues with port aggregation on business class products but the consumer size has been really sketch in my experience.
