A2cents
Dec 17, 2020Aspirant
RAX80 - CM1150v port aggregation cancels wired iMac ethernet (OK if single cable router-modem link)
RAX80 & CM1150v with aggregated link & gigabit Xfinity giving me consistent gig+ speeds using Xfinity app. Imac wired to RAX80 cannot complete a speedtest due to ethernet disconnecting ("fix": ...
Dec 17, 2020Guru - Experienced User
is the mac the only device effected when LAG is enabled on the CM and RAX router?
I presume you do have the mac connected to a open port not used by LAG right?
- A2centsDec 17, 2020Aspirant
RAX80 arrangement: WAN port & port #1 are LAG to modem; iMac is port #3 cabled direct without switch; port #2 is an unmanaged switch; ports #4 & #5 are managed switches (because ports #4 & #5 "must be" managed switches if used).
Other devices still function on LAN after iMac disconnects... for instance a wired Dell laptop accesses the web via router / network; various WIFI devices unaffected as well. Meanwhile Xfinity app (on iPhone, WIFI to RAX80) says speed 1.2 Gb/sec over LAG to modem / web.
A2cents
- FURRYe38Dec 17, 2020Guru - Experienced User
What happens if you connect the Mac to one of the switches?
The iMac problem persists unabated both using one of the managed switches AND with an unmanaged switch close-coupled to the iMac as a signal-booster/filter. Not many stones left unturned here.
Please note that a trip to my (nearby) Apple store lugging the iMac netted a clean bill of health from the diagnostics test (only mouse & keyboard connected) & ran fine on their network after a network "location" change (copy & rename to preclude corruption). Observations: 1) diagnostics does not involve ethernet; 2) their network was probably not Netgear LAG; 3) Apple not off the hook & they are investigating at the engineer level via movies and logs of events surrounding occurence.
thanks for your interest,
A2cents
So, does the LAG configuration work with other wired devices and with out the mac being connected?
