A2cents
Dec 17, 2020Aspirant
RAX80 - CM1150v port aggregation cancels wired iMac ethernet (OK if single cable router-modem link)
RAX80 & CM1150v with aggregated link & gigabit Xfinity giving me consistent gig+ speeds using Xfinity app. Imac wired to RAX80 cannot complete a speedtest due to ethernet disconnecting ("fix": ...
A2cents
RAX80 arrangement: WAN port & port #1 are LAG to modem; iMac is port #3 cabled direct without switch; port #2 is an unmanaged switch; ports #4 & #5 are managed switches (because ports #4 & #5 "must be" managed switches if used).
Other devices still function on LAN after iMac disconnects... for instance a wired Dell laptop accesses the web via router / network; various WIFI devices unaffected as well. Meanwhile Xfinity app (on iPhone, WIFI to RAX80) says speed 1.2 Gb/sec over LAG to modem / web.
A2cents
A2cents
The iMac problem persists unabated both using one of the managed switches AND with an unmanaged switch close-coupled to the iMac as a signal-booster/filter. Not many stones left unturned here.
Please note that a trip to my (nearby) Apple store lugging the iMac netted a clean bill of health from the diagnostics test (only mouse & keyboard connected) & ran fine on their network after a network "location" change (copy & rename to preclude corruption). Observations: 1) diagnostics does not involve ethernet; 2) their network was probably not Netgear LAG; 3) Apple not off the hook & they are investigating at the engineer level via movies and logs of events surrounding occurence.
thanks for your interest,
A2cents
- FURRYe38Dec 17, 2020Guru - Experienced User
So, does the LAG configuration work with other wired devices and with out the mac being connected?
- A2centsDec 18, 2020Aspirant
LAG works with or without the iMac ( and with ethernet port up or broken). Modem / LAG uptime 15 days before interuption for phone provisioning and 5 days since. The Xfinity iphone app shows speeds of 1150-1200 Mb/sec on gig account over LAG, or 850-940 Mb/sec over one/either leg. Knock on wood: LAG itself flawless.
A2cents
- FURRYe38Dec 18, 2020Guru - Experienced User
I'd say it's something with either the RAX router or Mac...very odd to see that though...
