sweetgerald
Sep 21, 2022Aspirant
RBR750 router with CM1200 modem - unpredictable and intermittent network speed drops
Hi Posting this here because I'm at a loss for where to go next. For period of 6 weeks I've experienced network issues where download speeds will drop to single digit Mbps or less. Sometimes complet...
Sep 21, 2022Guru - Experienced User
Modem:
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Orbi:
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
I just had my CM1200 online for a few weeks up until last weekend with my 8 series system. Smooth operation between these two.
- sweetgeraldSep 21, 2022Aspirant
Cable Connection:
Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency Startup Procedure
Procedure Status Comment Acquire Downstream Channel 423000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD honorMdd(4) Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 4 423000000 Hz 1.6 dBmV 43.5 dB 0 0 2 Locked QAM256 1 405000000 Hz 2.5 dBmV 44 dB 0 0 3 Locked QAM256 2 411000000 Hz 2.4 dBmV 43.8 dB 0 0 4 Locked QAM256 3 417000000 Hz 2 dBmV 43.7 dB 0 0 5 Locked QAM256 5 429000000 Hz 1.4 dBmV 43.3 dB 1 0 6 Locked QAM256 6 435000000 Hz 1.2 dBmV 43.2 dB 2 0 7 Locked QAM256 7 441000000 Hz 1 dBmV 43.1 dB 1 0 8 Locked QAM256 8 447000000 Hz 1 dBmV 43.1 dB 2 0 9 Locked QAM256 9 453000000 Hz 1.1 dBmV 43.1 dB 0 0 10 Locked QAM256 10 459000000 Hz 1.1 dBmV 43.1 dB 0 0 11 Locked QAM256 11 465000000 Hz 1.1 dBmV 43 dB 0 0 12 Locked QAM256 12 471000000 Hz 1.1 dBmV 43 dB 0 0 13 Locked QAM256 13 477000000 Hz 1 dBmV 42.9 dB 0 0 14 Locked QAM256 14 483000000 Hz 0.9 dBmV 42.9 dB 1 0 15 Locked QAM256 15 489000000 Hz 1 dBmV 42.8 dB 2 0 16 Locked QAM256 16 495000000 Hz 0.9 dBmV 42.8 dB 2 0 17 Locked QAM256 17 507000000 Hz 0.6 dBmV 42.5 dB 2 0 18 Locked QAM256 18 513000000 Hz 0.5 dBmV 42.5 dB 1 0 19 Locked QAM256 19 519000000 Hz 0.4 dBmV 42.5 dB 0 0 20 Locked QAM256 20 525000000 Hz 0.3 dBmV 42.4 dB 1 0 21 Locked QAM256 21 531000000 Hz 0.2 dBmV 42.3 dB 2 0 22 Locked QAM256 22 537000000 Hz 0.2 dBmV 42.3 dB 3 0 23 Locked QAM256 23 543000000 Hz 0.2 dBmV 42.4 dB 0 0 24 Locked QAM256 24 549000000 Hz 0.2 dBmV 42.4 dB 2 0 25 Locked QAM256 25 555000000 Hz 0.3 dBmV 42.5 dB 3 0 26 Locked QAM256 26 561000000 Hz 0.4 dBmV 42.5 dB 2 0 27 Locked QAM256 27 567000000 Hz 0.5 dBmV 42.5 dB 2 0 28 Locked QAM256 28 573000000 Hz 0.5 dBmV 42.6 dB 3 0 29 Locked QAM256 29 579000000 Hz 0.5 dBmV 42.6 dB 0 0 30 Locked QAM256 30 585000000 Hz 0.4 dBmV 42.6 dB 1 0 31 Locked QAM256 31 591000000 Hz 0.5 dBmV 42.7 dB 1 0 32 Locked QAM256 32 597000000 Hz 0.5 dBmV 42.6 dB 0 0 Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 5120 Ksym/sec 35600000 Hz 50.8 dBmV 2 Locked ATDMA 2 5120 Ksym/sec 29200000 Hz 50.3 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 22800000 Hz 49.8 dBmV 4 Locked ATDMA 4 5120 Ksym/sec 16400000 Hz 49.5 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV Downstream OFDM Channels
Channel Lock
StatusModulation /
Profile IDChannel
IDFrequency Power SNR /
MERActive Subcarrier
Number RangeUnerrored
CodewordsCorrectable
CodewordsUncorrectable
Codewords1 Locked 0 ,1 ,2 ,3 193 678000000 Hz -3.2 dBmV 40.5 dB 1108 ~ 2987 600103421 353012746 329 2 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0 Upstream OFDMA Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked 0 0 0 Hz 0 dBmV 2 Not Locked 0 0 0 Hz 0 dBmV Extended Upstream Transmit PowerEnable Extended Upstream Transmit Power
Current System Time:Wed Sep 21 10:06:34 2022System Up Time:2 days 00:43:54
Event Log
Time Priority Description Wed Sep 21 10:09:04 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Tue Sep 20 23:38:34 2022 Warning (5) Dynamic Range Window violation Tue Sep 20 23:38:34 2022 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Tue Sep 20 23:38:31 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Mon Sep 19 09:23:41 2022 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Mon Sep 19 09:23:20 2022 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Mon Sep 19 09:23:15 2022 Notice (6) TLV-11 - unrecognized OID;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6 Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Sun Sep 18 09:15:54 2022 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Sun Sep 18 09:15:49 2022 Notice (6) TLV-11 - unrecognized OID;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6 Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Fri Sep 09 17:36:16 2022 Warning (5) Dynamic Range Window violation Fri Sep 09 17:36:16 2022 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Fri Sep 09 17:36:15 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Fri Sep 09 15:44:56 2022 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Fri Sep 09 15:44:38 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Fri Sep 09 15:44:16 2022 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Fri Sep 09 15:44:06 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Wed Sep 07 18:16:12 2022 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Wed Sep 07 18:15:43 2022 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Wed Sep 07 18:12:40 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Wed Sep 07 09:50:15 2022 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Wed Sep 07 09:49:55 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Wed Sep 07 09:49:45 2022 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Wed Sep 07 09:49:24 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Wed Sep 07 09:48:55 2022 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Wed Sep 07 09:48:48 2022 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Wed Sep 07 09:48:47 2022 Notice (6) TLV-11 - unrecognized OID;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Wed Sep 07 09:48:39 2022 Notice (6) Honoring MDD; IP provisioning mode = IPv6 Wed Sep 07 09:48:06 2022 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Wed Sep 07 09:47:28 2022 Warning (5) MDD message timeout;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Wed Sep 07 09:47:27 2022 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Wed Sep 07 09:47:18 2022 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Wed Sep 07 09:47:16 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Wed Sep 07 09:46:35 2022 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Wed Sep 07 09:46:29 2022 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Wed Sep 07 09:46:24 2022 Notice (6) TLV-11 - unrecognized OID;CM-MAC=9c:c9:eb:34:e4:a0;CMTS-MAC=00:90:f0:29:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6 - FURRYe38Sep 21, 2022Guru - Experienced User
A few Correctables however not bad. Those could be a slight cable issue, bad connector or fitting or maybe a splitter.
I see Criticals that the ISP could look into. Check those warnings as well.
Can you elaborate on what I'm looking into with regard to criticals or warnings? Sorry - not sure what I'm looking at myself.
Xfinity has claimed there is no signal issue after 2 technician visits - during which time, each of them made cable adjustments inside or outside the house. Just looking for what ammo I might need to bring to show they're the source of any issue.
Does that log indicate anything that might be a source of my symptoms? I see warnings and criticals from last night, 9/20 around 11:30pm, which does correspond to when I was completely unable to connect to online access on an Xbox game.
Thanks, I appreciate the fast replies.
Regarding cables:
- using the LAN cables that came with the hardware (modem/router).
- no splitters as far as I know, from the ISP box to the modem (Xfinity tech did bypass some old stuff from previous homeowner's installation, on the morning of 9/7).
- Xfinity tech said the coax running up to modem was functioning well - it's in an enclosed finished room so I dont have easy access to replace anyway.
Regarding power:
- I've power cycled modem/router many times in the past month (including after firmware updates)
Regarding home details
- 2600 sqft, spread across 3 stories. Roughly 900 sqft/floor
- router and satellite are on different floors, opposite corners of the square-shaped house
- far enough away from other houses that I cannot pick up anyone else's wifi, if that is what you mean by wifi neighbors
Regarding configuration:
- using out of the box channels (not familiar with it enough to have changed anything).
- I have not power cycled again since I noticed there was a satellite firmware update this morning, that I had not noticed before. Just updated the satellite RBS750 to same firmware as the router.
- i have not done a factory reset and scratch setup since I had it configured and set up initially 8 months ago. Thought about it, but there's never a convenient time to do it.
sweetgerald wrote:
Regarding cables:
- using the LAN cables that came with the hardware (modem/router). <CAT6 is recommended.
Regarding power:
- router and satellite are on different floors, opposite corners of the square-shaped house, <What is the distance between the RBR and RBS?
- using out of the box channels (not familiar with it enough to have changed anything). <Try setting channel 1 and 40 on the RBR. Also set 40Mhz only Under Advanced Tab/Advanced Settings/Wireless Settings. I would also maybe set the power to 50% as well.
- I have not power cycled again since I noticed there was a satellite firmware update this morning, that I had not noticed before. Just updated the satellite RBS750 to same firmware as the router. <Be sure that if FW updates are available that the RBS set updated first then the RBR lastly.
- i have not done a factory reset and scratch setup since I had it configured and set up initially 8 months ago. Thought about it, but there's never a convenient time to do it. <I recommend giving this a try on the entire system and setup from scratch.
- Ensure the laptops wifi and ethernet adapter drivers are fully up to date as well.
- will look into CAT6 if needed
- distance between RBR and RBS is about 35 ft in the horizontal plane, and about 6 ft in the vertical plane, on different floors, opposite corners of the house. So let's just assume a bit over 35 if my trigonometry is right.
- what will setting channels do?
- i just generally do the fw updates when the orbi app presents them to me
- Can do a full system reset if there are no other leads to pursue first
- regarding drivers - i'm also seeing the same symptom on all devices simultaneously. Phones, laptop, game console, tv, streaming sticks. It seems unlikely it's a device issue.
- I assume you mean power to mean the signal coming from the ISP into the modem, rather than "electrical" power to the hardware, correct?
- Both Xfinity techs noted an unusually high signal coming from the pole to the house, but both techs did some cabling rearrangement that they suggested would resolve the issue. The second tech did say he'd create a ticket to have someone look at something at the pole, but that is outside the scope of me hearing back from Xfinity about.
- Is there a specific log error or warning I can cite to Xfinity for support? Or is this something to address with my hardware?
