sweetgerald
Sep 21, 2022Aspirant
RBR750 router with CM1200 modem - unpredictable and intermittent network speed drops
Hi Posting this here because I'm at a loss for where to go next. For period of 6 weeks I've experienced network issues where download speeds will drop to single digit Mbps or less. Sometimes complet...
sweetgerald
- will look into CAT6 if needed
- distance between RBR and RBS is about 35 ft in the horizontal plane, and about 6 ft in the vertical plane, on different floors, opposite corners of the house. So let's just assume a bit over 35 if my trigonometry is right.
- what will setting channels do?
- i just generally do the fw updates when the orbi app presents them to me
- Can do a full system reset if there are no other leads to pursue first
- regarding drivers - i'm also seeing the same symptom on all devices simultaneously. Phones, laptop, game console, tv, streaming sticks. It seems unlikely it's a device issue.
- I assume you mean power to mean the signal coming from the ISP into the modem, rather than "electrical" power to the hardware, correct?
- Both Xfinity techs noted an unusually high signal coming from the pole to the house, but both techs did some cabling rearrangement that they suggested would resolve the issue. The second tech did say he'd create a ticket to have someone look at something at the pole, but that is outside the scope of me hearing back from Xfinity about.
- Is there a specific log error or warning I can cite to Xfinity for support? Or is this something to address with my hardware?
Sep 21, 2022Guru - Experienced User
correct, power on the coax line.
it could sure be something from the pole causing it. Even something simple as a not tight enough connector on their end.
- sweetgeraldSep 21, 2022Aspirant
Is the Correctable Codewords of Downstream ofdm channels in red below of any meaning to me in this situation? Apologies, since I don't know what I'm looking at/for.
I guess I'll continue monitoring the occurrences, and try to check the modem's connection page for power levels/monitor error logs for a while, and reach out to Xfinity if there are continued issues?
Oddly enough, I just started to call Xfinity customer support, and their automated message suggested there was work being done an outage for my address, and I couldnt get an agent until that was resolved. I never experienced any outage today, outside of a small drop for a few minutes this morning.
Downstream OFDM Channels Channel Lock
StatusModulation /
Profile IDChannel
IDFrequency Power SNR /
MERActive Subcarrier
Number RangeUnerrored
CodewordsCorrectable
CodewordsUncorrectable
Codewords1 Locked 0 ,1 ,2 ,3 193 678000000 Hz -2.1 dBmV 41.1 dB 1108 ~ 2987 625850788 371332109 329 2 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0 - plemansSep 22, 2022Guru - Experienced User
Its more your uncorrectables and the log we're looking at.
But if they're doing work, that could be the issue
