Soulfire
May 01, 2025Follower
Re: C7800 Nighthawk Firmware Release Information
Having the same issue right now. Bought this thing so I can install my own DNS shield and I can't do any of that or use parental controls until the firmware is updated. Can't even use the Netgear app...
May 01, 2025Guru - Experienced User
You bought it to run DNS shield.
Which is what exactly? Is it a 3rd party service for DNS?
If so, you can go in and change the DNS without issues. I've ran PiHold fo years on all my devices.
