HomeTown
Mar 29, 2020Aspirant
Can you help me improve my wifi connections on a C7100 Nighthwawk AC1900 WiFi Cable Modem Router?
Recently all my wireless devices (tablet, laptop, phones) are connecting at much lower speeds (90 Mbps) compared to my wired PC (550 Mbps.) Is there anything I can do to get my wifi speeds back up? ...
Mar 29, 2020Guru - Experienced User
Set 20/40Mhz Coexistence to 40Mhz only.
HomeTown
Mar 30, 2020Aspirant
I attached a picture from a WiFi Channel Scanner.
