kozowh
Jul 25, 2017Aspirant
Re: Can't connect to router (even after reset)
I have a similar problem with a few twists using a C6300 under Windows 10. I was having connectivity issues with an application and one of the suggestions was to alter the NAT passthrough which I wa...
DarrenM
Jul 26, 2017Sr. NETGEAR Moderator
Hello kozowh
Try to go to 192.168.100.1 see if it takes you to the modem page and should be a link to get into the router.
DarrenM
