kaitlin4599
Mar 09, 2021Aspirant
cant log in to my router C6300
ok so i bought a netgear modem router combo off ebay seller listed it as new in box seller said they bought the modem but realized it wasnt what they needed for the isp service they had so they tosse...
kaitlin4599
Mar 10, 2021Aspirant
didnt works still cant log in
kaitlin4599
keds are all lit i can access the internet how do i ping it?
- plemansMar 10, 2021Guru - Experienced User
So if the led's are all lit and you're able to use the internet, that implies its not bad.
Try using a different web browser and/or pc to access it.
Try using the 192.168.100.1 address.
- kaitlin4599Mar 10, 2021Aspirant
ok i was able to ping the router and saw no errors
- plemansMar 10, 2021Guru - Experienced Userdid you try a different pc/browser?
And try accessing it using the 192.168.100.1?- kaitlin4599Mar 10, 2021Aspirant
yup tried that no dice
