dadabunchie
Mar 11, 2021Aspirant
CAX 80 Reboot SSID Changed
CAX80 rebooted sometime last night and suddenly SSID changed to a different name. Spectrum probably dropped (still having slowness issues) and caused the reboot. Anyone experience this before? ...
Aug 07, 2021Guru - Experienced User
I don't have access to actual case #s
So after the reset and setup from scratch and saving off a new config, a restore still dosen't work well?
Keep in contact with NG support.
CompuSmith wrote:
Thank you for your reply.. I did do exactly that. If you can, see my Netgear case #44921600.
vkdelta
Aug 08, 2021NETGEAR Employee Retired
what SSID did it drop to?
