dannydiggz's avatar
dannydiggz
CAX30 Poor Downstream Connection / Partial help
I've had this CAX30 router/modem for about 10-11months. Pro installed by Cox (1gig)   I had issues with stability in the past, but it seemed fine for months and now all of a suden back to stability...
  • Kitsap's avatar
    Kitsap
    Feb 08, 2025
    Just took a second look at your latest cable data.  It appears Cox has enabled mid-split in your area.  I can see your OFDM channel 2 is running at 918 MHz and the power level is way below specification.  There is a good chance Cox did that in the past year.
    Whether you only use one connection or not, there could be a splitter in your coax connection.  Many old splitters are rated for 5-860 MHz and cause a significant signal loss above that frequency range.  The splitter needs to be replaced.
