DayneJake1
Jan 29, 2024Star
CAX80-100NAS with Xfinity wifi texting failing
We have Xifinity internet and Xfinity mobile. The AX6000 was purchased by us and then connected to Xfinity. Starting in December, both my wife and my Samsun Galaxy S21 phones started having issues ...
Feb 01, 2024Guru - Experienced User
Do either of you happen to have a spare external router on hand by chance?
Can you get the brand and model of there modem, wifi router and iphones and iOS version please?
DayneJake1
Feb 01, 2024Star
I have my Arris SBG7400AC2 that I replaced with the CAX80.
Both kids have Xfinity modem routers that they pay the monthly rental on. Getting the models.
I am gathering a debug log now as well. sent 2 messages to them and both stuck cycling between sending and queued.
Would the Armor function come into play perhaps on the CAX-80?
- FURRYe38Feb 01, 2024Guru - Experienced User
Please disable Armor with in the Nighthawk app, then after it's disabled, power OFF the CAX80 for 30 seconds then back ON. Then test a text message.
Possible that if you could put the Arris back online to test this at some point.
- DayneJake1Feb 01, 2024Star
I would have to reactivate the Arris. Not an option at this point.
The Nighthawk app has the activate trial message when I click on the Armor icon.
I can disable it in the debug page it looks like.
Under the menu top left corner of the app, go to Settings, look for Security, Armor should be seen here and a slider button.
I haven't tried the check box in the debug page, suppose this could work too.
I also don't seem to be able to get the debug logs to download etc.
What browser are you using?
How much time after you select the save button are you giving? I've noticed it can take several seconds before you see the download appear in the browser, give it say 30 seconds or so.Debug logging is being saved on the modems memory area. Then when saving, your browser will download the compiled .zip file to where you have the browser set to save files too. I recommend the desktop.
