DayneJake1
Jan 29, 2024Star
CAX80-100NAS with Xfinity wifi texting failing
We have Xifinity internet and Xfinity mobile. The AX6000 was purchased by us and then connected to Xfinity. Starting in December, both my wife and my Samsun Galaxy S21 phones started having issues ...
Feb 01, 2024Guru - Experienced User
Please disable Armor with in the Nighthawk app, then after it's disabled, power OFF the CAX80 for 30 seconds then back ON. Then test a text message.
Possible that if you could put the Arris back online to test this at some point.
DayneJake1
Feb 01, 2024Star
I would have to reactivate the Arris. Not an option at this point.
The Nighthawk app has the activate trial message when I click on the Armor icon.
I can disable it in the debug page it looks like.
- FURRYe38Feb 01, 2024Guru - Experienced User
Under the menu top left corner of the app, go to Settings, look for Security, Armor should be seen here and a slider button.
I haven't tried the check box in the debug page, suppose this could work too.
- DayneJake1Feb 01, 2024Star
Says Activate trial that menu as well.
Will try the debug menu way. How vulnerable does that make me?
