DayneJake1
Jan 29, 2024Star
CAX80-100NAS with Xfinity wifi texting failing
We have Xifinity internet and Xfinity mobile. The AX6000 was purchased by us and then connected to Xfinity. Starting in December, both my wife and my Samsun Galaxy S21 phones started having issues ...
Feb 03, 2024Guru - Experienced User
Interesting find. 🤔
Wondering why a factory reset and use of a different SSID name and password or maybe just a different SSID name would effect this. Or if removing the NH app and re-installing though I think I saw in a different forum someone had mentioned they removed the NH app, then re-installed it and then messages started to work. No sure how the NH app would play a roll in all this. Ya, seems like there is something happening that needs to be figured out.
DayneJake1 when you FR your unit, did you setup from sratch using the NH app or PC and web browser?
DayneJake1
Feb 03, 2024Star
I did everything by Web GUI.
Only time I touched NH app was to look at turning off the Armor 2 days after the reset and reconfigure.
Mine did work for about 12 hours after reset then slowly started the issue again. My wife's never worked even after the reset. She came home after mine worked for about 7 hours. (with the issue reappearing for me a few hours later.)
