DayneJake1
Jan 29, 2024Star
CAX80-100NAS with Xfinity wifi texting failing
We have Xifinity internet and Xfinity mobile. The AX6000 was purchased by us and then connected to Xfinity. Starting in December, both my wife and my Samsun Galaxy S21 phones started having issues ...
Feb 06, 2024Guru - Experienced User
Checking with the both of you to see if the following on the CAX80 has been checked?
Disable IPSec ALG from GUI (ADVANCED->WAN Setup-> Click "Disable IPSec ALG" checkbox) and give it a try.
Thank you.
DayneJake1
Feb 09, 2024Star
I have made this change and will test for a few days. So far it looks good after 2 hours.
- FURRYe38Feb 09, 2024Guru - Experienced User
