AlexanderSextus
Nov 04, 2021Star
CAX80 can't upload 5GHZ
Im having serious issues trying to get this figured out, ive tried playing with everything for teh last 6 hours to get my uploads to work in 5ghz mode. Im literally 25 feet from the router and any fi...
- Jun 14, 2023
Firmware version 5.1.1.2 is what everyone needs to push for to be released.
Jan 19, 2023Guru - Experienced User
Can you try with Smart Connect enabled and try current 5Ghz channel your using then try channel 48 or 149.
Yes, any issues seen after a FW update will need a factory reset and setup from scratch.
Last time I checked this on mine 5Ghz is working on current version, however performance is being limited to help debug the problem. I had uploaded several Gbs of data over 5Ghz and all completed fine. Smart Connect enabled I believe when I tested mine out.
Does 2.4Ghz do same thing or just 5Ghz?
ilikecerealtoo wrote:
What Firmware version is currently loaded? v2.1.5.2
Are the uploads stopping or stalling or just going really slow? Usually they just fail. I found with the Craigslist app I could spam retry on each photo and eventually get it to work after 5-10 retries.
What channels are you using? 8 @1200Mbps & 56 @4800Mpbs (verified best channels with Wifi Analyzer)
Region Selection Region: North America (locked)
Enable AX - This WiFi mode will enable AX features such as OFDMA Yes Enable Smart Connect No Wireless Network (2.4GHz b/g/n/ax) Enable SSID Broadcast yes Enable 20/40 MHz Coexistence yes Name (SSID): my network (not my real SSID) Channel: Current : 8 Mode: Up to 1200 Mbps Transmit Power Control: 100% Security Options WPA2-PSK[AES] + WPA3-Personal «« yes
Wireless Network (5GHz a/n/ac/ax) Enable SSID Broadcast yes Name (SSID): my network-5G (I just add -5G) Channel: Current : 56 Mode: Mbps Up to 4800 Mbps Transmit Power Control: 100% Security Options WPA2-PSK[AES] + WPA3-Personal «« yes
Wireless Advanced Settings (5GHz a/n/ac/ax) Enable Wireless Router Radio: yes (all the same for both 2.4 & 5) Fragmentation Length (256-2346): 2346 CTS/RTS Threshold (1-2347): 2347 Preamble Mode: Long Preamble
Smart connect enabled or disabled? Disabled
Is Armor, SPC or Traffic Meter enabled? Nope for all. I use Cloudflare DNS for both ipv4 & ipv6... Logs there don't show anything being blocked.
I don't remember if I have done the full reset since v2.1.5.2 but really? Is this necessary after every time we update the fw? This is getting kinda old... I can try setting DHCP all in the 100s. That sounds weird but hey, whatever works. I will try it.
house0fpayne
Jan 27, 2023Aspirant
I can confirm that this new V2.1.5.2 did not fix the 5GHz uploading issues with the CAX80 on Xfinity. I can't even send emails at certain times. Also, if I try to upload and files to my server that is over 50MB it drops the connection. Pushing git commits that are larger don't work either. Is there ever going to be a fix for this or do we all just need to buy a new none Netgear router? I did noticed that I had more luck uploading larger files until I downgraded my xfinity plan from the Gig to the 800Mbps. It all works every time on 2.4GHz.
- FURRYe38Jan 27, 2023Guru - Experienced User
What is the brand and model# of the 5Ghz wifi adapter your using with the CAX80?
How are you uploading files? Web browser or other app?
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
- house0fpayneFeb 03, 2023Aspirant
I'm using a Mac Book Pro 2019.
I"m uploading files with FileZilla or to bitbucket through my terminal.
The uploads are stopping and erroring out.
2.4GHz is set to auto channel currently using 7. 5GHz is set to 36.
Smart Connect is disabled.
I don't know what Armor or SPC is but Traffic Meter is disabled.
I did a factory reset after I did the FW update.
I don't know where to set the DHCP IP settings.
This seems to only happen still on 5GHz with anything over 50MB.
- FURRYe38Feb 03, 2023Guru - Experienced User
Does it still happen if you change channels to 1 on 2.4Ghz and 48 or 149 on 5Ghz and Smart Connect enabled?
