AlexanderSextus
Nov 04, 2021Star
CAX80 can't upload 5GHZ
Im having serious issues trying to get this figured out, ive tried playing with everything for teh last 6 hours to get my uploads to work in 5ghz mode. Im literally 25 feet from the router and any fi...
- Jun 14, 2023
Firmware version 5.1.1.2 is what everyone needs to push for to be released.
naveennelluri
May 23, 2023Aspirant
yatman60 I'm all in to try any beta software, that fixes it. It's strange to need an NDA, as this is not new software or hardware, but merely a bug fix, that's plaguing everyone apparently. But what do i know. Eagerly waiting and fingers crossed. Thanks for the update.
lexneverland
Jun 08, 2023Guide
Well, I won't be holding my breath. yatman60 I will believe it when I see it. I have spent so much time with Netgear engineers, customer service reps, here in the forums.
Any word on when this firmware update is being released?
- yatman60Jun 14, 2023Star
- FURRYe38Jun 27, 2023Guru - Experienced User
Can you two re-confirm this FW version?
Is this a correct version number? Seems this maybe incorrect.
- yatman60Jun 27, 2023StarYes. This is the correct number. You will probably need to call support directly and ask for it.
