AlexanderSextus
Nov 04, 2021Star
CAX80 can't upload 5GHZ
Im having serious issues trying to get this figured out, ive tried playing with everything for teh last 6 hours to get my uploads to work in 5ghz mode. Im literally 25 feet from the router and any fi...
- Jun 14, 2023
Firmware version 5.1.1.2 is what everyone needs to push for to be released.
Xellious
Jun 17, 2023Tutor
I just bought a CAX80 and running into issues with the 5ghz when uploading and working with the Microsoft Azure portal. 80% of the time I load a resource page there is an api call failure and it can't get the resource info. I have 0 issues on the 2.4ghz network and have tried all posted troubleshooting steps with no luck.
This is absolutely ridiculous.
Mrhooha
Jun 17, 2023Aspirant
I have a case open with Netgear at the moment. I suggest you open a case to and provide this thread.
- XelliousJun 17, 2023TutorI have an open case, but the phone system just drops my call as soon I choose the CAX option, so haven't been able to talk to anyone about it.
I got the 5.1.1.2 FW yatman60 mentioned and it has resolved the issue I was having with Azure and the api call errors, and may have resolved the issue with uploading. Comcast having issues in the area today, so only did a little testing with a 750MB upload to One Drive. Failed halfway through first time, but succeeded second.- soundlink21Jun 24, 2023Aspirant
Hey have you been able to sort out the issue on the CAX80 ?
I am on the same situation and about to trash it
- FURRYe38Jun 24, 2023Guru - Experienced User
Would be recommended to contact NG support and ask about the beta FW that seems to be available.
