Mellojosh
Mar 23, 2022Star
Re: CAX80 Multi-gig ethernet port dropping
I am also having this exact issue. Just with the 2.5g port. The port functions for an undefined period of time then the blue light goes off, the connection stalls, then it drops to 1g. Even on 1g the ...
Homeautoguy
Jun 20, 2022Aspirant
I'm having the same issue. Anyone no one how to fix this?
- GACubanJun 20, 2022Star
Yes, I agree.
They said they would replace my unit, but what's the point? They don't even have any to send right now due to shortage (or they know it won't do anything to fix the multi-gig port issue).
I had a great router, so I disabled the WiFi on the CAX80 and it seems to behave well that way. AT&T is supposed to bury fiber here in the next months, so maybe that will be my out too.
- jasmc5000Sep 23, 2022TutorAny update on this issue? I've had the nighthawk for a month now and love everything about it minus the 2.5gig port dropping to 1gig.
- FURRYe38Sep 24, 2022Guru - Experienced User
What do you have connected to the 2.5Gb port?
What CAT# lan cable are you using?
Modem in router mode?
What FW are you using?
