Mellojosh
Mar 23, 2022Star
Re: CAX80 Multi-gig ethernet port dropping
I am also having this exact issue. Just with the 2.5g port. The port functions for an undefined period of time then the blue light goes off, the connection stalls, then it drops to 1g. Even on 1g the ...
GACuban
Jun 20, 2022Star
Yes, I agree.
They said they would replace my unit, but what's the point? They don't even have any to send right now due to shortage (or they know it won't do anything to fix the multi-gig port issue).
I had a great router, so I disabled the WiFi on the CAX80 and it seems to behave well that way. AT&T is supposed to bury fiber here in the next months, so maybe that will be my out too.
jasmc5000
Sep 23, 2022Tutor
Any update on this issue? I've had the nighthawk for a month now and love everything about it minus the 2.5gig port dropping to 1gig.
- FURRYe38Sep 24, 2022Guru - Experienced User
What do you have connected to the 2.5Gb port?
What CAT# lan cable are you using?
Modem in router mode?
What FW are you using?
jasmc5000 wrote:
Any update on this issue? I've had the nighthawk for a month now and love everything about it minus the 2.5gig port dropping to 1gig.- jasmc5000Sep 24, 2022Tutor
Desktop computer wit 2.5 gig realtek nic latest drivers.
I've tried cat6, cat7 and currently cat8. The cat8 seems to do a little better but still drops out multiple times a day.
Yes the Modem is in router mode. I'm currently using it as a gateway for xfinity gig pro plan. When light is blue I can constantly get speeds around 1400/40 when it is white I'm capped at under 1 gig
Firmware 2.1.3.5. I was under the assumption that xfinity handles the firmware updates.
- FURRYe38Sep 26, 2022Guru - Experienced User
Are the cables UTP or STP? STP is recommended CAT6A STP on the multi-gig port.
For CAX80 users, can update FW for the router portion of the unit. You might try:
