Mellojosh
Mar 23, 2022Star
Re: CAX80 Multi-gig ethernet port dropping
I am also having this exact issue. Just with the 2.5g port. The port functions for an undefined period of time then the blue light goes off, the connection stalls, then it drops to 1g. Even on 1g the ...
My_Username
Nov 29, 2022Apprentice
My CAX80 would not run 2.5Gb dependably when connected to an Asus XG-C100C. It would always run when first connected but would start dropping after varying lengths of time. CAX80 firmware did not seem to have any effect up through the current 2.1.5.2. Network cables Cat6a and Cat8 may have shown a little difference - or I may have wanted to see a difference. It wasn't a cure in any event.
The PC I was running the XG-C100C in failed for unrelated reasons and I rebuilt my network around a laptop and NAX box. The NAS is an Asustor AS6702T running Truenas Scale. The CAX80 and Asustor AS6702T have been running happily at 2.5Gb for a week now with no issues. I left the Cat8 cable in place FWIW.
Maybe the issue lies partly or mostly with the AQC107 boards. They do run stinky-hot. That can't help.
- DumaineNov 29, 2022Tutor
So as I mentioned somewhere earlier (or maybe on the other thread), I got this thing used (as=is) off the bay, so it could be very well have other issues. What I don't understand is this. Just what difference does it make which NIC is in the PC when I only have the issue when wireless is Enabled? As soon as I disable it I run forever. In other words, what does the Multi gig port have to do with wireless section of the Gateway?
- FURRYe38Nov 29, 2022Guru - Experienced User
Possible that there is some odd interference happening with these particular branded adatpers that these adapters maybe effected by the CAX80s wifi when thats enabled.
What do you see on the adatper, in windows and on the front of the CAX multi gig port LED? I presume the color must change from BLUE to something else when this happens?
So far Realtek here is working. I need to find out what the MSI Tomahawk board uses. I presume Intel or Realtek maybe.
Would be a test if you got a Intel or a Realtek board or a 2.5Gb only board in to try and see if the same thing happens.
Thanks for your info and details.
Ya I see those particular chip set boards are all 10Gb supporting. You and Dumaine have these boards. I haven't checked into these boards so I presume these could be a factor in what you two are seeing.You might try adding some forced are cooling to these boards to see if this might help. I see they have big heat sinks as they should however in a cramped PC box, possible these could not be getting enough cooling or air flow...
I have a Startech 5Gb USB to ethernet adatper and when i use it the entire heat sink block gets fairly warm.
