tamanaco
Nov 05, 2021Apprentice
CAX80 Updated to Firmware 2.1.3.5
This morning I was presented with Firmware Update 2.1.3.5 for my Netgear CAX80. After thinking it over for a couple minutes I took the plunge and installed it. The Firmware Update installed fine, but...
- Nov 10, 2021
Comcast tech just left. The signal coming into the house was apparently extraordinarily strong. He added some kind of step-down attachment onto the coax connector that balanced the upstream vs. downstream power a little better. CAX80 is now reporting a good signal.
So the new diagsnostics weren't in error. They ID'd a legitimate problem as intended!
Nov 10, 2021Guru - Experienced User
Have them check the modems connection status page for signal values while they are there.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
nsne wrote:
Thanks, tamanaco. Good to know. A Comcast tech is scheduled to be out here sometime in the next two hours to have a look at things. If your diags are working correctly, then it's likely a valid issue with my coax run/provisioning.
nsne
Nov 10, 2021Virtuoso
