erchicago85
Apr 10, 2024Aspirant
Re: CAX80 with Xfinity wifi texting failing
I'm also having the same issue with my CAX80 (see thread with the same topic) where the OP marked the solution as using a custom firmware of version 2.1.5.2. Picture texts over wifi aren't going throu...
Apr 11, 2024Guru - Experienced User
Other user posted they contacted NG support and got it from them.
erchicago85 wrote:
I'm also having the same issue with my CAX80 (see thread with the same topic) where the OP marked the solution as using a custom firmware of version 2.1.5.2. Picture texts over wifi aren't going through and am also having issues uploading files.
Has anyone else applied this fix or have a copy of the modified firmware?
- erchicago85Apr 14, 2024AspirantNetgear support insists there is no beta or custom firmware for the cax80. They had me change my DNS which didn't help.
Netgear, can you connect me to L2 support?- FURRYe38Apr 14, 2024Guru - Experienced User
Contact NG support.
- erchicago85Apr 25, 2024AspirantDid you ever get this resolved? Netgear support states that FW 5.1.1.2 no longer exists and continue to close my cases without a solution.
