EMH
Aug 16, 2021Tutor
CM1000 Upstream Light Keeps Turning Amber
Hello all, I've been trying for weeks to resolve an issue with a Netgear ADT Hub. ADT has been out several times to no avail. I've tried everything but can't seem to locate the problem. The only...
EMH
Aug 21, 2021Tutor
OK. Will explore solution in near future. In the meantime, can anyone elucidate the problem hiw US power causes (i.e. what are the symptoms)?
vkdelta
Aug 22, 2021NETGEAR Employee Retired
you will suddenly loose US bonding (and thats why you see Amber US light since it is working in single US channel mode)
AND/OR you will partial US service
AND/OR you see lot of T3/T4 as well when modem cannot push even more power.
