rkalinka's avatar
Jun 29, 2022
CM1000v2 cannot access 192.168.100.1
How many times did you have to perform the factory reset?  I am having the same problem - performed a factory reset as specified in the note - no change in behavior.
  • Kitsap's avatar
    Kitsap
    Aug 29, 2022
    rkalinka wrote:
    Kitsap - I don't think my Netgear modem has those configurations available to it as it's only a Modem (not a router).  When I get a minute do more testing on my environment, I'll see if there is a way to drop in a static route on the MODEM (but I don't think so).
    That being said, I could always try to put the static route you mentioned on my ROUTER to see if that fixes the issue - certainly a good idea.  That being said, I was having the same URL failure problem when I hooked up my laptop directly to the modem (bypassing the router completely) so I doubt putting a static router on my ROUTER will fix it.... but, I will chase this down as anything is possible and I would like to get it working again.
    rkalinka
    The static route for access to your modem is a configuration you apply to the router.
