Synica1's avatar
Synica1
Guide
Mar 08, 2019
CM1100 IPv6 Problem (Xfinity)
Hi everyone, I replaced our C7100V with a new CM1100 yesterday. After a bit of wrangling on the phone with Comcast, it's activated and working... but only on IPv4. Firmware version after the Comcas...
  • vkdelta's avatar
    vkdelta
    Mar 10, 2019
    CM is just a bridge modem. It is not do anything for CPE side (LAN side) Ipv6 other than just mere forwarding it.
    Comcast does DHCPv6 for the routers and provides a delegated Prefix (PD) along with it.
    Not sure what firewall you are using, but most linux ones support DHCPv6 with PD.
