BCFL
Jun 16, 2024Follower
Re: CM2050V firmware update
Does Netgear monitor this community? I've not had any problems with the modem until the past 2 months. This is the modem approved by Comcast and is compatible. But, I am now experiencing connection dropping and the download light is blinking. I've done the standard troubleshooting to no avail. Firmware update is recommended, but, apparently, there is no firmware update. These are rather expensive modems, which is fine if they are dependable and supported. But, rather worthless if not usable.
1 Reply
If the download light is blinking, it isn't locking in all the channels.
For the most part, it tends to be a line/cable connection issue as usually their either work or are bad. Not usually only a couple channels going bad.
Got a copy of the cable connections and event logs?
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
