Ianr1
Aug 08, 2024Follower
Re: CM2050V goes offline every few weeks - how to troubleshoot
I purchased the Netgear Nighthawk CM2050V back in July and set it up with Comcast. It worked great for three weeks and then last night it just stopped working - no internet connection. All of the fro...
Aug 08, 2024Guru - Experienced User
When you get the new one, (if you do) check its incoming power levels. I've seen the incoming power level to high and cause them to go bad.
