demonick
Nov 27, 2023Aspirant
CM600 won't negotiate 800down/100up
Thank you!
I am experiencing the exact same issues as the OP. Xfinity, an 800 Mbps upgrade activation, and just seeing 400/24 Mbps. Ordered a CM1100.
After Xfinity installed the boot file...
greeno
Nov 27, 2023Apprentice
Even with the cm1100 I’m limited to 200 mbps upload. The claim is netgear and xfinity aren’t on the same page for bonding protocol.
If you look here, https://assets.xfinity.com/assets/dotcom/projects/cix-4997_compatible-devices/2023.10.23%20Full%20List%20of%20Compatible%20Devices.pdf
You’ll see they only guarantee 945Mbps down. Best guaranteed upload speed is 460-ish Mbps.
demonick
Thanks for the heads-up on the upload speed. Not a gamer so 200 Mbps will do me fine.
