Equivalentx
Apr 19, 2023Aspirant
Re: Loss of Internet to desktop applications but no to web browsing
Model number: AC1900 C7000v2 Firmware: V1.03.08 OS Windows 11 Desktop apps like Steam client, Discord Client, Riot Client, even Windows update are unable to connect to internet but i can acc...
Kitsap
Apr 19, 2023Master
Equivalentx wrote:Model number: AC1900 C7000v2
Firmware: V1.03.08
OS Windows 11
i can access internet through web browsers like google chrome and microsoft edge speed tests come back as ok
350mbps download
10mbps upload
and 19 ms latency.
sorry for format and missing information didn't see header.
Most likely some Windows settings. The screen snips I have attached are from Windows 10. They will be similar but not exact as for Windows 11.
Under Settings, go to Network & Internet and check the network profile classification. It should be Private and not Public. This controls internet access for the machine and the applications. Snip attached.
If you are concerned about an individual application, go to Control Panel\All Control Panel Items\Windows Defender Firewall\Allowed apps. There is a list of applications and two columns to specify internet access. This only applies if your are using Windows Defender. If you have some other anti-virus program installed, you will have to figure it out from there. Snip attached.
Kitsap
Apr 19, 2023Master
Second snip.
